Discussion Starter · #2 ·
Here is what it looks like after I went over it with a scotchbrite pad for the brushed aluminum look. I took some sheet aluminum and made my own template, then cut it out and used a industrial drill press with a metal hole cutter bit to cut the three holes. Then I radiused the corners and used industrial breaks to bend the aluminum into its current shape. Then I just scuffed it up. I still need to drill liscence plate mounting holes then thats about it. I kind of want to make a few more with ZX6R or Ninja or something like that where the three holes are. I know you won't be able to see the lettering when the liscense is on but it would still be pretty cool.
http://photos.yahoo.com/bc/nathanho...os&.dnm=DSCF0017.jpg&.src=ph&.view=t&.hires=t[/1MG]
Life is short, but sweet for certain...
Love to see it bro but the links aren't working!
"It's not the size of the Gun but the caliber of the Bullet that makes the biggest hole!" -SDF
