1 - 2 of 2 Posts
hey just got the speed tactics fe kit it came with instructions which i followed, but im having a hard time figuring out how to disconnect the stock signals so the wires come out and mount the new bracket i wanna use the stock signals even tho the kit came with led blinkers which i may use also cam with led bolt lights how do i hooke them up straight to the battery or splice em into the plate light wire???
Have you pulled off the throttle side tail section for acces to the blinker harness connectors ? And NO on hookin the plate light to the battery , cut the oem wires and solder it in or if no access to a soldering gun then "butt" connectors are your friend .
1 - 2 of 2 Posts
