1 - 8 of 8 Posts
I have a 07 zzr600 motorcycle, my front brakes are out. When I’m not moving they build pressure, but when Im commuting somewhere they disappear. No pressure or anything. What could it be?
Jack up front wheel, use a pencil or some sort of pointer, spin the wheel and hold the pointer close to the rotor you should see the gap modulate, if it is a long warp it will be gradual.
I think you have a blown ring on your master cylinder. It can create the illusion of pressure until you actually use the brakes and then lose pressure when the fluid passes by the piston. I blew one on a Harley Sporster when I had to make an emergency stop on the freeway. You can replace the internals with minimal time and skill. A rebuild kit should be cheap. All the bleeding in the world won't cure a blown master cylinder.
1 - 8 of 8 Posts
