i just bought a crashed 06 636 i got it runnin and it wont rev over 9k and the fi light is on but when the light is off it revs fine but the idle is up near 4k and cant adj at all. i had to mess with the tip over sensor to get it running,but now im at a point were im confused. anybody have this problem or know what to look for.
Got lime? I do
was the throttle linkage smashed? it should have the adj nob under the seat on the left side, also theres an adjustment at the throttle. not sure bout that fi light. could be a throttle position sensor got messed up in the crash.
Well if its not reving past 9k when the fi light is on, pull the code and see what its for.. The light doesnt come on just for any reason, there is something out of its normal parameter that the ecu sees it.. Untill you pull the code you probably wil be confused..
Discussion Starter #4
how do you pull the codes the bike was hydo locked and had water in the tank so i fixed thoughs now this is happeing
search the forum for dealer modes and codes or buy a service manual
