1 - 9 of 9 Posts
Powerhungry
huh? im not sure what your asking..
theres a positive neutral finder, for when you are stopped. will only shift up to N from 1st.
and, your not able to shift to 2nd, unless your moving..above i think its 15 mph....
ok sorry about the confusion. say you're rolling down the road at 25 mph and want to put it in neutral while rolling, will ur bike let u or will it skip neutral?
Powerhungry
it CAN be done, but its difficult. it will try to jump up to 2nd, or down to 1st. depending which way you're trying to shift it.
takes a VERY light touch to hit neutral while moving. i dont suggest trying it.
Yep it can be done.
And for the positive nuetral the bike has to be pretty much full stopped any spinning of the shaft causes ball bearings to spin out and allow the gear to move past netrual and into 2nd. When stopped the ball bearing on the top of the shaft falls into a channel not allowing the gear past netrual. I had a probelm in one of my transmissions I swapped out the stupid thing was sticking.
Powerhungry
Yep it can be done.
mine has stuck on occasion also. can sometimes get to 2nd when stopped...rarely tho.
Discussion Starter #7
I hate that about these bikes. I've raced dirt bikes my whole life so I'm used to rolling to a stop in neutral.
Got lime? I do
rolling to a stop in neutral is going to be hard, but if your used to it, you may could perfect the technique.
Powerhungry
not a good idea anyway.
you should be aware of whats behind you, as your stopping. if someone isnt paying attention, you may have to move forward. cant do that in nuetral. the split second it takes to shift into gear...it might be too late...
1 - 9 of 9 Posts
