1 - 2 of 2 Posts
Greetings people, while I am driving the bike I noticed that when I come to a stop and change to neutral, the bike after a few seconds jumps to first gear. This has started happening recently and not always. I had changed the clutch oil (Valvoline ABS Brake fluid DOT 3/4) and Engine Oil(Mobil Synthetic 10W40 for Motorcycle).
Any thoughts...
Thanks
92 Ninja ZX11
21K
inspect the shift star for rear or being loose.. the spring holding the roller against the star should be uber tight.. have some good tension on it..
if this looks ok, you might have a slightly bent fork or worn fork pin guide on the shift drum..
hopefully it's simple..
good luck
1 - 2 of 2 Posts
