1 - 2 of 2 Posts
Hey guys, I have a 2017 Kawasaki ninja 300 that doesn’t start and a 2014 ninja 300 that does, the 17’ has brand new battery, spark plugs, oil, coolant, and it used to start and run only while the starter was being engaged. Now it won’t spark. I swapped coil packs between the 2 bikes, my 14’ runs like a babe, everything works on the 14’ but when I put it on the 17’ it doesn’t, coil packs check out good, same with spark plugs, and fuel system works great. However I think it’s the wiring harness that doesn’t work? I get very VERY low volts on the coil pack cables (before the coil packs, coming from harness). Looking for some help and insight. Thank you very much, feel free to comment whatever and thank you
This morning was a great day to ride so I decided to start up my Ninja. All of a sudden I couldn't get it to start at first. Eventually I hold up the throttle so it won't stall.
1 - 2 of 2 Posts
