Ive switched out the junction box, left hand light controll assembly on the bars, both head light bulbs and the entire headlight assembly ...... Still no headlight or high beam all other lights work ...... PLEASE HELP !!!!!!!!
I bought an 04 ZX 6r it didn't have a lot of fuel in it when I bought it so I filled it up with 93 octane and it was running amazingly. After about 60 to 70 miles about enough time for the fuel that was in it to run out and start running the new fuel I put in, it started acting like it was run...
Bought the bike, 2004 zx6r, was riding it home and it was running great. After about 50-60 miles it acted like it was running out of gas and finally died. I haven't been able to get it started back. Need help!
Hi all, so last week I dropped my bike, bent just the rear peg, not even a scratch on the fairings and it shut down while laying on the right side, now the oil light is on and this weird noise suddenly showed up. The oil seemed to not flow properly visible in the glass before I pulled everything...
Hi, I have a 2004 600rr track bike, just bought it. Noticed the expansion bottle was empty for coolant so topped it it and it just came out of the tube in the bottom of the bottle, am I right in thinking the bottom hose should be fasterned to the rad not the top on as it has been?. Cheers steve
i went to install an ape cam chain tensioner left it all the way out and i think the timing skipped so i tore it all down tried to adjust the timing where is tdc on the lower part of the cam assembly i set it at the t wondering if its the I and which mark have to be level on the top assembly...
