I have a 1998 zx9r that needed frame work due to an accident...well im finally starting to put it together now and its almost back together.
here is my problem...when I try to turn the bike over all I hear is the fuel pump and nothing else. When I jump the starter relay it cranks but still no spark. It's not the starter relay though bc i've already replaced that.
when i put the bike in first it still says its in neutral also...no matter what gear its in my neutral light is always on.
also my horn does not work...dont know if this would have anything to do with it...before I took the engine out it tried to turn over just fine by pushing the ignition switch so im thinking something is wired incorrect. Neutral switch is wired correct and I believe I have all the grounds but possibly not.
I have been tryin to figure this out for a few weeks now and i have no idea what it could be. any help is greatly appreciated. thanks in advance.
