What size is the nut that holds the rear axel on a 636? I need to adjust my chain, but I don't know what size the nut is. Is the torque setting 80ft-lbs? Thanks for the info.
Craig
Torque setting is 125 ft lbs - Nut size - um I think I've been using a 1 - 1/4" socket, but I'm not sure, I just know what works and what doesn't!
32 mm I think.
94 ft-lbs torque (from service manual)
You will need a breaker bar or a lot of muscle (or both) to break that nut loose.
It's on hella tight.
