1 - 13 of 13 Posts
Hey guys i have tried searching for this and can't seem to find any info on it. I am looking at an 06-07 Zx10r Ohlins Damper and was wondering if it would fit my 05 Zx6r? I would appreciate any feedback.
Thanks! :D
I have no idea if it'll fit but I would try contacting Ohlins directly or an Ohlins dealer. They may be able to help you out.
One of our forum sponsors is an Ohlins Distributor:
Hardracing.com : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Ohlins, Ohlins Forks, Ohlins Shocks, Ohlins Dampers, Ohlins Supsension
Thanks alot for the input. I was looking around their store and WOW wish i had the Loot.
Oh and I saw that the 05 zx6r was 63mm and the 06-09 was 65mm so idk if its going to work :(
but already sent them a message asking so hopefully it can some how work.
Call up Ohlins usa dirrectly, they are very helpfull over there. They helped me with a problem I had with my damper. I'm sure they can answer any questions you might have.
Thanks Nuar i will try that tomorrow already 8pm over here
Hey man 2mm is nothing to worry about it is the stroke of the damper not the body.
here is the thing,
the zx10r has a different mounting surface area than the 05/06 zx6r...they have 2 mounting bolts and a raised tab the bracket sits on.
so a kit for the 10r won't work on your bike.
there is a couple viable options,
if you want to do this on the cheap with an ohlins damper, but even then not super cheap.
I run my ohlins damper on the underside of the ram air intake..the ohlins kit sits just like the hyper-pro on top using a big ass mounting plate that uses the gas tank mounting bolt to hold it in.
you can make a bracket to hold the damper easy enough, buy the folr clamp easy enough, just find the damper for a good deal is the issue..
That Fighter Guy
2006 Kawasaki ZZR600 street fighter
Yeah even an OEM Ohlins damper used isn't cheap. I used an OEM GSXR damper with a home made bracket to mount it to my tank bolts. It does the trick though it's not as pretty as an Ohlins.
Discussion Starter · #8 · (Edited)
Thanks for the advice guys.
I think I will just purchase either a Scotts or a GPR
or maybe even a hyperpro which prob wont happen.
Btw i was also wondering is a rotary damper best for my bike
since its an easier install? correct me if i am wrong.
+1 with JdGun your best bet is making a mounting kit. Which plenty of people do all the time. If you have a the money or know a friend that can do machining work for you you can turn out some trick-parts and even consider selling a kit to attach the 06/07 ZX10R OEM Damper to the 05/06 ZX6R/RR.
Btw i was also wondering is a rotary damper best for my bike since its an easier install? correct me if i am wrong.
That's a loaded question.
I don't think there's a "best" damper out there.
Everyone here will argue one way or the other why this damper is better than or worse than the other.
I think the important thing is to GET a Steering Damper. Which one you get is mostly preference and some small differences.
Rotary Steering Dampers are more compact and survive a crash more easily than Linear Steering Dampers. But I have heard that Linear Steering Dampers offer more feel.
Rotary Steering Dampers (like the Scotts) also normally have more ways to adjust for a given riding style.
So I think it's really preference, I have a Scotts Steering Damper, that's what I had on my 03 ZX6RR and that's what I bought for my 2006 ZX6R. The only thing I don't like about the Scotts Steering Damper is the fact that I had to drill and tap two holes in my frame to mount it. Other than that I highly recommend the Scotts Steering Damper.
But like I said it's mostly preference the important thing is to get one.
Do a search on this forum you'll find hundreds of threads discussing different styles/types and models of steering dampers.
I have an '06-'07 zx10r ohlins damper sitting in my garage that I might sell if I get a good price for it.
1 - 13 of 13 Posts
