1 - 11 of 11 Posts
Im wanting to change my oil and this is the first time i will be doing it to this bike. What brand filter and filter number do you use and what type and how much oil do you use?
Thanks
-M1a
Try the search function on here next time u have a question, theres several different post on this topic with detailed instructions.
Mobil1 M-110 filter available at any auto parts store. Oil is a highly debated and personal choice. Do a search as this has been covered alot.
With a filter change, the bike should take around 4 quarts of oil if I recall correctly.
Discussion Starter #4
sorry i did a search and didnt find anything that had to do with types of oil and oilfilter number. If you can find a post for me that would be great
I did my bike last week, just used the owners manual for instructions, didn't have any issues, much easier to do on this bike than my old one actually. I just got a kawi filter from the dealer and some kawi oil, I'll put something fancy in next time.
Discussion Starter #7
i guess i skipped over the how to section b/c all i could find in there is how to change the oil which i already know how. But the second post that has the types of oil helps and with xtremes post on the filter number i have everything i need now.
Thanks
-M1a
I changed the oil on my 03 zx6r, it was pretty simple I actually changed it with out taking my fairings off. (because they are busted and zip tied and safety wired in strategic areas) so I drilled a small hole in the lower left fairing get a driver through to loosen the retaining ring around the filter.
use Mobil1 filter or Puralator filter PL14612 or PL14610
use regular oil for the first couple of oil changes, then switch to synthetic after 1,500-3,000 miles, depending on how hard you break it in. I use Mobil1 15w-50 full synthetic for riding season, and Mobil1 5w-30 full synthetic for winter storage.
1 - 11 of 11 Posts
