1 - 13 of 13 Posts
I believe its ~10 ft/lbs. Keep in mind it has an aluminum washer, usually a good indicator of very low torque requirements.
A good "rough" method would be to hand thread and tighten the bolt, then give it 1/8 turn with the wrench, that's all it needs.
I'll take 222 ft lbs for $500, Alec... Buy the repair manual, then you will definitely know which one it is; or you can average out all of the above not including mine. I have a 2002 and my repair manual says 14.5 ft lbs, how much more different can it be on an '03, but this is straight from the kawasaki repair manual.
Originally posted by iroman
BTW, no offense guys, but go with Rob Lee's spec.
WRONG! Here's proof sucka [:p]/forum/uploads/strong bad/oil_torque_spec_1.jpg/forum/uploads/strong bad/oil_torque_spec_2.jpg
Now stick that nut between your cheeks n' crack it! :D
Originally posted by Strong Bad
The proper torque spec for the oil drain plug is 29 n/m - 1.0 kgf/m - 87 in/lb
Actually, look at line 15 of your post with the manual posted. It plainly says that the engine drain plug takes 22 ft.lbs. of torque.
I guess you and Rob were both off. You just read the wrong line. Your first spec is for the drain plug (29nm) but the rest (1.0kgf/m and 87 in/lb) is for the oil pan bolts.
Discussion Starter · #13 ·
Thanks for posting that bit from the manual--I've already ordered one, but it hasn't arrived yet...I'm breaking in the bike so I wanted to get the oil changed before I put too many more miles on it (It's too hard to stay off the thing!)
1 - 13 of 13 Posts
