I recently purchased a 2004 Bayou 250. When I conducted an oil filter change I removed only a filter. In prior research I found that there was a tube that is inside the filter that is removed a d place inside the new filter then installed. My question is, does the Bayou 250 not have this tube. At the time this filter is just sitting in there. Any helpful info is welcomed.
Discussion Starter #4
Does any one know which way the tube is inserted. One end is tapered and the other is he circumference of the tube. Both the motor side and the oil cover have recessed areas. Given I did not have one in it when I opened it up and this tube having a bypass piston and spring I dont want to install it backwards and cut the oil off. Any help is welcomed. New tube and parts are on the way.
