It's not leaking anywhere but out of where the wire runs. I had to replace a broken bolt after replacing the stator and when I ran the motor it was a constant stream of oil. Didn't do this prior to breaking the bolt so I'm not convinced it's the gasket. Any thoughts?
https://imgur.com/a/DoATP
There's really only two things that could cause that to leak. Either your stator cover is cracked / warped and no longer has a good sealing surface on the left side of your case. Or you didn't remove enough of the old paper gasket off of the sealing surface when you replaced your stator causing it not to create a seal. (seen this 100 times) I am however assuming you did put a new gasket on when you reinstalled the stator cover, those are meant to be a one time use only.
