Where is hoser??
You say "seems to be coming from".....and then "was a loose bolt".
Is it leaking, or did you fix it?? Your use of past and present grammar confuses me.
FWIW: I have not heard of many oil leaks on 636s
--David
after an oil change on my bike it started pissing like a harley out of the drain plug. turns out the previous owner striped the shit out of the oil pan and the dirty nasty oil built up sediment around the plug keep it from leaking before the oil chage. ended up getting a new pan and gasket and no more leak.
