hey everyone, i've got a bit of a problem. i've noticed an oil like substance dripping in the fuel petcock area. now from what i can tell without removing anything is that it is dripping from above the petcock, on to it, and then down on to the frame. does anyone know where this would be coming from? has anyone had this problem before? any tips would be great. thanks.
Only the FAST survive.
well man it aint oil cause there is no oil flow that high up or arounf that area on your bike, could be a leaky petcock or maybe a crappy weld on your tank???? beats me! are you sure its not gas?
off like a prom dress!
Your best bet is to remove the gas tank and look around the engine for a leak on the valve cover, or a disconnected hose somewhere. Other than from the motor itself, there's no reason why there should be oil in that location.
BC.
