Is this a cause for concern and I should take some out? I put 3 US quarts (recommended is 3.3) and it's still at this max line for some reason. Bike is on level ground, ran to operating temp and cooled down in this pic. Thanks for any insight.
Hood Automotive tire Motor vehicle Automotive design Automotive exterior
Is this a cause for concern and I should take some out? I put 3 US quarts (recommended is 3.3) and it's still at this max line for some reason. Bike is on level ground, ran to operating temp and cooled down in this pic. Thanks for any insight. View attachment 139681
As you noted you're "at the max line". There's a minimum line and a maximum line and as long as you're at or inside them you're fine.
Moderator
Even if you're slightly over the max line, you're still fine. If you can see the top of the oil in the window, you're fine.
