Everything was working fine. The engine was running so I guess the oil level was showing a little lower than normal. So I turned it off and added oil. I ended up overfilling like a 1/4 inch above the top mark. I ran it like that for like a minute before noticing. The light was still fine then. So I turned it off and took out the oil filter to drain some oil. I jacked the rear up so enough drained. I was just over the full notch but I thought it would be fine since the oil drained out of the filter too. So I put it back and started it. I don't know if the light was on instantly or not but a few minutes later I noticed the light was on so I turned it off. I checked the level and it was fine.
What I've done so far:
- started the engine then unscrewed the filter a little to burp it.
- got a new oil filter
- drained all the oil and put it back
- checked the oil pressure sensor and all the connections seem good.
still the light stays on. I tired to run it for a few minutes but I don't want to do more just in case something happens.
What else can I try? The only other problem I can think of is the filter. It's a cheap Fram one(both new and old). I've searched and saw those weren't great for pressure. I go get a different brand tomorrow if nothing changes.
I'm sure it has something to do with me overfilling and then draining out the filter place. So any other ideas on how to get that air out or any other ideas at all? The bike does run fine with no weird noises or anything
