what kind of oil do you guys use? also what weight?
any you recomend/
any you recomend/
I use the same stuff. Just get whatever 10W-40 you like. I like synthetic, my buddy runs conventional, both bikes run great.I use Amsoil 10W-40. 10W-40 is recommended in the service manual. You can choose whatever brand you are common with. I chose to use Amsoil because they show statistics that its better than other motor oils. And from what I've have been researching, most people believes Amsoil is the best motor oil.
For my 2008 Ninja 250R
extra virgin olive oil...what kind of oil do you guys use? also what weight?
any you recomend/
Conventional 10W-40 motorcycle oil I've seen in auto parts stores (typically Valvoline) is usually $3.99 or $4.99 a quart. If you can't spend $20 on oil and $15 on a filter, then that's just sad. My buddy used car oil in his bike for a long time, but I could never convince him to use motorcycle oil until he gave in one day and gave it a try. He came to me telling me, "wow, the bike feels noticeably better with the motorcycle oil. It shifts better, too. I guess you were right, Larry. Ha ha." I just looked at him with a "duh" look on my face and said, "crazy how that works, huh?" LOL.IF for some strange reason, you wish to use an auto or diesel oil, make sure to look or the following Specs.
An API SG or SG/SH. A higher API Rating may be used but the oil Must then carry a JASO MA or better yet, JASO MA2
For a diesel oil, API CG or CG/CH.. or the JASO MA or MA2
The Best isn’t cheap
Cheap isn’t The Best
Bob
And that has all the same ratings and whatnot you see on the back of a bottle of 10W-40 motorcycle oil? I've heard of people using that, but due to the lack of "motorcycle" on the label it drives me away. $19 a gallon is a freakin' deal considering I pay $10 a quart for synthetic motorcycle oil. I'm gonna have to take a bottle of my motorcycle oil to Wal-mart and compare the two to convince me.Rotella T6 is some good stuff too!
Walmart sells a gallon for $19
What makes it a Motorcycle Oil is the "Motorcycle Oil" on the label. In fact, I once had some car oil and I scrapped off the labels and wrote Motorcycle Oil on the bottle and immediately it was 100x better. I could tell the difference immediately as it shifted 100x better and added 200hp. I didn't even have to touch the shifter it just read my mind and shifted right when I wanted it too.It lall depends on what you want out of your oil or out of your bike.
What I see above is "All Diesel Oils are Alike"... Quite far from the truth. Rotella happens to have a Self-Imposed JASO MA Rating making it wet clutch compatible. This does not make it a "Motorcycle oil" but does meet the minimum requirements set forth by the OEM.
If you look at other diesel oils and they do not have the JASO MA, they MUST carry an API CG or CG/CH Rating. If the Ratings start at CH or higher, the oil should NOT be used.
With a car oil, the API Ratings needed are SG or SG/SH or must have a JASO MA.
Some Premium M/C oils will also have additives to give a JASO MA2, Specific Anti-Wear additives for the tranny and Ant-Rust and Corrosion Inhibitors to protect during short periods of Non-Riding.
Oil, is the Lifeblood of your engine. The oil filter, is the Kidney that keeps it clean.
Bob
People, such as yourself, that have no idea what they are talking about but try to impose your ill illusions of knowledge of a subject should remain in the shadows of darkness and keep their mouths closed, ears open and fingers idle and maybe, just maybe, you will learn something and be able to respond on a subject with some intelligence instead of a lack there-of.What makes it a Motorcycle Oil is the "Motorcycle Oil" on the label. In fact, I once had some car oil and I scrapped off the labels and wrote Motorcycle Oil on the bottle and immediately it was 100x better. I could tell the difference immediately as it shifted 100x better and added 200hp. I didn't even have to touch the shifter it just read my mind and shifted right when I wanted it too.
If it also has a picture of a motorcycle on the bottle it adds up to 300hp.
