Need a bit more info...
Is that a slip on canister, or a full exhaust system? I'm assuming slip on because of the price.
Also, what bike do you have? Year, engine size, etc.
Usually, slip on's don't require very much jetting changes when you compare them to the stock muffler, but that's only if the jetting was spot on with the original muffler. If your bike is bone stock, then re-jetting might help it run a bit better.
Oh yeah, technically, you don't actually NEED to buy a full-on jet kit. You can buy a couple jet sizes smaller and larger than what is currently in the carbs, and a small bunch of washers, and get almost the exact same results for a hell of a lot less money than a full-on jet kit.
BC.
I didn't do it, I swear.
BC.
