Here's what I did.
1. Removed all smog and KLEEN equipment.
2. Section of emissions hose and assorted vacuum caps.
3. I cut a section of hose to go between the pair valves.
Once the KLEEN device is removed and the hose is installed, the pair valves are essentialy disabled.
I then capped the 3 ports on the TB's with vacuum caps shown here.
4. Since I removed all the smog equipment as well.
I re-routed the fuel evap vent to the blue port on the gas tank and pluged the red port.
