Hello to those who have a map for pawer commander 3 kawasaki zx 6r 2007 yoshimura rs-5 slip on k&n air filter Block off plates and Kleen air mod and no Exhaust Valve servo
Moderator
Your best move would be to get a custom tune.
Let's be analytical here. The only mods you have are:
- Yoshimura RS-5 (which has VERY little impact since it is just a slip-on exhaust AND is downstream of a CAT. Total PEAK effect, per Yoshimura itself, is + ONE hp)
- aftermarket air filter (which does almost nothing unless coupled with very aggressive changes in airflow via cams and FULL exhaust)
- Block-off plates (the only effect of these is on closed throttle deceleration where it stops backfiring. NO change in power)
- Kleen air mod (again, really no perceptible effect on power)
- No exhaust valve servo (This affects ONLY noise and emissions. Not power)
You don't need the PC3 OR a tune at this point. That will change only once you remove the CAT or put on a FULL exhaust (i.e. incldues changing the header).
Sorry if this disappoints you, but I didn't want to see you spending money and effort on a pointless mission.
Jim G
