Well I finially broke down and tried to see if a high mount from a 636 would bolt up to our bikes. I bought the entire set up for 55 bucks header and all so I didnt figure I would be out much if it didnt work. To my disbeliefe the header mounted right up and the mid pipe fit perfect, and the can just needed a tad bit of tweeking on th mounting bracket so as not to hit the tail. It came out very well in my opinion, but I think I am going to make my own bracket to mount the can as I can only use 1 hole currently. Anyway here are the pics.
yeah i was suprised to when i tried to see if it would fit.
i was going to make a custom exhuast from my stock one and the 636 so i could use 636 high mount but it works and gives you a little better low end power and torque since the 636 header has cross over pipes.
also you could cut a little off the mid pipe where it connects to the header and that will help with clearence and make the angle of the pipe match the tail better.
my 02 has a high mount.. I'm thinking it was originally a Micron high rise but i **** off the micron can and installed a new Yoshi, looks 10x's better.
