i dont have that bike, but if its not obvious, then you probably have to pull the tank.how do you remove the plastic trim right under the gas tank on an 08 650r
I was thinking about covering in carbon fiber wrap
That worked came off easy, and are now wrapped in carbon film it looks sweet!Pop the seat, take out the push-pin, and pull the plastic, give it a little force for it to come off it's rubber mounts. Very easy, definitely NO NEED to take off the tank first.
