lioke i mentioned before i took the cover off to poilish when i noticed the coil was on the back of the case. i put the cover back on and it was really hard. lil did i know the shaft theat sits inna gear fell off and was wedged in there when i was trying to tighten it....!!!!! it bend the coil a lil and bent the shaft... the bike does not start, it just clicks...... but the shaft doesnt go into the gear now cuz its bent... is that why it just clicks???? please tell me all i need is the lil shaft
I think your stator coil should be ok.... doesn't look that bad. I'd definitely replace that shaft though, as your gear needs to spin freely. Even if you get it to work with the bent shaft, that's a lot of friction at high rpm's. Sorry about your luck. [V] I always look at an exploded diagram when I start taking things off. That shaft shouldn't cost too much.
