I just got a JArdine RT-1 for my 2004 636, but i never got the owners manual and i got no clue how to SAFELY remove the fairing..does anybody know, or has anyobdy done this?
There is nothing on this forum about how to do this, even when u search...the explanations are quite flimsy...[xx(]
[:GayHasselhoff]
thanks alot!
how do you take out the plastic rivets without damaging them???
And how do i pull out those things im supposed to pull out?? with a wrench??
sorry im ignorant, trying to learn
thanks
Rivets: Take a small allen key and press the middle part in, then just pull the rivet out.
The other things are just a plastic press fit for the bodywork, just hold the fairing and pull out the inner (under side of the front fairing) and it will just pop out, there's two at the front and one that attaches to the plastic triangle in front of the radiator, top corner.
thanks alot loco....
but i notices 3 bolts above the side fairing, do i need to remove all of those?? or is your picture for removing all the fairings, not just the side ones??
anyway..thanks..ill get to it now...ill post up some pics when im done
Here's one more pic, but no, this is just for removing the main fairings and have another look at the first pic, all of the bolts needed to remove are in that pic with arrows.
