I want to install an ignition advance on my 02' but i'm not sure what i'm doing. To get the nut off after I have the cover and everything off do I need an impact gun and is it bad if the whole thing turns while trying to loosen it?
Also, i'm guessing that the piece that I need to install is behind a few things, right?
Any help or advice would be great!!!
Thanks,
John
Once you get the cover off it is a matter of taking off one part, the round metal rotor that triggers the ignition, and replacing it with a new one. Mine was held on by a allen head cap screw but yours may be different. The thing is actually attached to the end of the crank so you can keep it from turning by just putting it in gear or by holding the hex on the hub of the rotor with a wrench.
