I bought a a dynojet power commander from OPPracing. I ordered the Zx636R one. They sent me the ZX6RR. Can I use this one? Is it compatable or do I need to send it back?
an answer ASAP would be quality thanks
I believe that they are the same unit just with different maps installed. Download the correct map from DynoJet and you should be fine.
Same thing happened to me. It's the loaded map that matters, because the same pc works for both R and RR. I called dynojet and the place I ordered it from to make sure before installing it.
