Hi all,
If you change your standard exhaust for a performance one and have to get rid of the power valve do you lose any low down power?
Not sure to buy a performance pipe or gutt the original one and keep the power valve (exhaust valve)
Also if you but a 'race can' do they usually come with the brackets for the number plate/indicators?
Thanks all!!
with an aftermarket exhaust you will lose just a little down low, but not a big deal, if tuned properly with a power commander.
Powerhungry
Hi all,
Thanks all!!
actually, when i did it. i gained throughout. there was NO loss down low.
then when i fabbed the valve back in, with the akra, there WAS a low end loss. in fact, there was a total loss, throughout the entire range.
its def not a POWER valve on this bike.
and yes, most slip-ons come with a provision for mounting the plate, and signals.
Discussion Starter #4
Great thanks.
I guess it's just there for noise immissions then, not like the old two strokes i.e KR1s/TZR etc.
Oh one last question....
The performance can I intend to buy (micron race can) states 'no adjustment needed to fueling' but looking at other threads the ZX6R runs lean anyway. Would you say it definately needs a power commander or will it be ok to run i.e no damage to engine?
Thanks again
