hi , i had a little chrash and its now something wrong with the injektion sistem ( it doesnt start) how can i chek the sistem ? Gas pomp is ok
What exactly are the symptoms? Does the starter motor turn over? Does the engine turn over? Does it even power up? Did you pull the codes? Are all the fuses ok?
My first thing to check would be the neutral safety switch, tip-over switch and the clutch safety switch. Sometimes if they get smacked hard in a wreck they will not operate properly.
There are dozens of things that are associated with startup. None of it is hard to diagnose, it just takes time, patients, a voltmeter and more patients.
i`ts all ok - starter is workink , engine to , when i spray in air filter box engine start helper (its a sprays to eazy start the engine) the engine runs a cuple sec. and stops . and there is no gas smel (only the smell from the spray) . how to chek the fuses ? and the neutral , tip-over and cluch safety swich ? where is the swiches ? thanks
