HEY I JUST STARTED TO DO PLUGS ON MY BIKE WHEN I NOTICE THAT THERE IS NO PVC VALVE. BOTH OF THE BREATHER HOSES ON TOP OF MY MOTOR ARE COUPLED TOGETHER. IS THERE ANY REASON FOR THIS OR IS MY BIKE JUST RIGGED UP? ALSO IF YOU COULD TELL ME WHAT THE GAP SHOULD BE ON THE SPARK PLUGS IT WOULD BE GREATLY APPRICIATED. THANX
It's not a PCV valve. There used to be a valve there that injected air into the exhaust. Somebody removed it. You can just leave it like that unless you want to buy some parts from Kawasaki that are probably pretty expensive. The plugs should be gapped .7-.8mm or .028-.032".
