Hi, I was recently installing some frame sliders on my 2005 zx6r, and I had a question about the right side upper engine mount. This side is very strange to me because I have never seen a sleeve set up like this.
My question is this:
I am not putting the upper right engine mount bolt back in, and I made the mistake of adjusting the coller/sleeve. I am refering to the piece which is threaded on the outside and has a hex input on the inside, and through which the engine mount bolt runs through.
I need to know how far out or in the sleeve/collar should be. Should it be turned all the way counterclockwise so that it is out as far as possible? This would allow the engine to sit nearly flush with the frame. I can't find this info anywhere the service manual is too vague, please help!!!
