Hi guys,
I installed my PCIII yesterday and Fuelmoto downloaded the map for my Akra slip on and the accelaration pump fueature.I never had a powercommander before on any of my bikes so it's absolutly new for me.I already could tell that the bike runs alot better in idle again since it was bouncing up and down in the rpms after installing the akra slip on when letting it run in neutral.I haven't had a chance to ride the bike but hopefully will do this later today.
When I turn on the ignition the green light bar goes up and down and when I start the bike and let it run in idle the first green light in the low section is on and when I rev up the rpms more of the green lights start to come on deppending how much rpms I let the bike run,is that how it should be so I know I installed the PCIII right and it's working ok and I'm ready to go?
Thanks alot
As you rev it, the PCIII shows the mixture, so if it's going up and down that's fine. It's working. The information it displays is used for tuning.
