Hey guys,
As most of you know I have just recently completed my Ninjas HID retrofit. I noticed though that when my bike fires up the bulb will flicker for about 3-4 seconds before finding enough power to smoothly start warming up. I find it strange because it has a wiring harness with a relay, which I thought was supposed to store the correct ammount of power to power them smoothly.. (correct my if I am wrong).
Ocasionally (more often than not) I will fire the bike up, and the low beam will flicker then not light up at all. If I turn the bike off, and back on 3 seconds later it will turn on.
Now I read online that an HID kits use more power initially, but is more efficient at steady power. I have never blown the 10A fuse, but am wondering if a 12A or 15A fuse would be reccomended to give it that extra grunt it seems to need? Or is it really super dangerous and high risk of fire if I upgrade from the 10A to a 15A?
Could it maybe be low battery power? I had my bike on a charger already before the season started and I've never had the bike fail me during a turn over, but maybe after the winter season the battery has gone bad? I really don't want to replace the battery... I just dished out hundreds on new tires + install.
It's embarresing to show my new lights, fire up the bike, watch them flicker then die as the bike continues to run.
Any of your thoughts, advice or suggestions are appreciated.
Thanks so much.
