Most radar detectors have an aux power cable that would normally plug into a cigaret lighter. All you need to do is cut off the end and wire it up to the battery or you could find a power source that is only on with the ignition. There should be a spot in the fuse box that is hot with the ignition on.
You don't have to be faster then the bear, just faster then your friend.
