I laid the bike down a while ago everything was fine untill recently my left turn signal stopped working. Then the fuse blew. I replaced the fuse and the right signal worked but not the left. Another fuse blew. I replaced it also and still the right worked but not the left.
I removed the unit on the left handle bar that houses the horn switch and blinkers and it was cracked. So I replaced it with one from a guy off ebay. Still no left signal? WTF, any ideas?
A side note...when I installed my rear signals w/the fender elim. from Bertja the left signal wires were swapped and I blew 2 fuses before I figured out that the diagram was wrong and the neg was actually positive and the pos. was actually neg. But they worked great untill i went down. I know this is kind-of random and a bit newb...but any help is appreciated.
