Well my 99 ZX9r is missing a few teeth and is jumping them occassionaly, i dont know how to tell if i have a stock or upgraded rear sprocket. It looks like it has a renthal sticker on it, but i dont know if its stock, upgraded or what...any ideas, thanks.
if your breaking teeth - its most likely an aluminum sprocket-- if your happy with your accelleration, just count the teeth and replace it... with a steel sprocket(doesnt matter what brand). If the chain is jumping off the sprocket- I wouldnt ride it until its replaced - your really asking for trouble..... .02 worth
if i got a different size sprocket, i would have to put a different chain and front sprocket on too wouldnt i?
Originally posted by jimzx9r
If you're busting teeth off the sprocket, your chain is probably trashed already anyway.
Ditto start off fresh with a complete front rear and new chain combo.
As long as you use the same pitch you will have no trouble. I believe the 99 uses a 530 chain. Also make sure your chain has'nt stretched to much.A chain life will vary, depends on maintenance,lubrication,etc.The sweet spot imho is a 15f/42r combo.I'm running a 15/43 set up,which is awsome but you do lose a little to much top end speed. About 160mph and your done while hitting redline.
chains usually come in 520 or 530-- I agree-->'m pretty sure a 99 came with a 530-- just make sure the front/rear sprocket and chain are the same pitch and you should be good. sprocket tooth number doesnt matter- you'll just have to re adjust your chain tension to fit the smaller/larger sprocket
