What parts do u guys lubricate periodically aside from the chain. And how do u lubricate the cables?
Pull the lever back, and spray the lube in with the red end piece that comes with the can. I don't know the name of it, but it's long and red and is usually taped to the side. Other then that, you won't have to lube anything else too often. I used to just take the bike in for a complete service every 10K miles, that way I'd be covered.
you can buy cable lube tools that help get the liquid in down the cable better if you want, but really this is all I do to lube my cables too...
You also want to check tires pressures, chain slack, coolant levels etc...
I think the Kawaski manaul that came with the bike gives you a pre-ride checklist...
