Haven't seen anything posted on this too lately, so I'd thought I'd bring it up. Owners manual calls for checking the chain slack every 600 miles...I just check mine when I lube the chain (owners manual every 400 miles).
The procedure for checking chain slack is on page 108 of your owners manual. Essentially:
I did my alignment with the string method and found my wheel to be 1 and 1/2 flats off on the adjuster nut. I found when doing the string method that taping the loose ends of the string to something heavy yet movable (full coke can, oil bottle) is better than trying to hold it steady when you move from side to side of the bike for fine tuning your string.
Before anyone posts "why is this in the 250 section" or "search"...here's a preemptive :stfu:
- Lift chain up/down at midpoint between front and rear sprockets.
- Rotate chain to the tight spot.
- Measure. Spec for chain slack is .8 to 1.2 inches.
- If out of spec, tighten/loosen by
- remove cotter key, loosening the rear axle 24mm and 17mm sockets
- loosening the locknuts - 12mm
- turning the adjusting nuts appropriately (equal turns on both sides) - 14mm
- tighten locknuts
- tighten axle 72 ft/lbs tq, insert cotter key.
