I'm putting the clutch plates back in the same order they came out, but does it matter how the tabs line up as long as each plate's tabs are properly seated in the slots in the outer clutch basket?
I'l try the question a different way. Every 4th (or maybe 5th?) tab has a notch in it. Do the notched tabs on each plate need to be aligned with the notched tabs on the next plate, or should they be staggered from one plate to the next, or does it matter?
the last 2 fibers up against the clutch basket goes in 1 certain way, the tabs need to be in the notch u took them out of so pay attention, also the last tab will need to go back in the same notch also, make sure u torque everything down to factory specs when puttin back together, ive changed mine myself several times, just remember same way they come out the same way they go back, just pay attention and u will be fine
