you mean the hose to the petcock? it should have came with a reatiner clamp.
Member since 8/30/02. Forget what the post count says!
[you mean the hose to the petcock?
not on the 03' .. there is a connector called the hose joint which attaches to the delivery tube coming out of the fuel pump. It slides on and off.
Petcock ?? ... Hmmm ??? ... I think I had a Norton 850 Commando that had one of those as I remember ... :D ... all joking aside that's the everyday benefit of fuel injection .. no petcock!
oh my bad i didnt see that you typed 03 in your message....wait you didnt[:p]
yeah you cant install a jet kit either on fuel injected[^] just power commanders
Just a tip that when you reinstall the gas tank make sure you get the connector snapped all the way back on otherwise gas leaks all over -not good (if it's on properly it will slide back and forth about 2mm on the metal tubing - if not it is rigid and won't move at all)
