Hey guys. I was wondering, can I use this to remove the ignition from the upper triple clamp? I found it at Kawasaki's official website. Rivet tool set.
No. That INSTALLS rivets, it does not remove them. The ignition is held to the triple via headless bolts. You have to drill the rivet style heads off to be able to remove the bolts. Replace with new bolts that fit or get the proper bolts from kawi.
get a drill press with a big drill bit. i have done it on my 04, its really easy. pop he heads off and it will slide off the studs. then you grab pliers and back out the remainder of the stud. ronayers has headed replacements available.
