To add to agon2welz..
When you remove the 4 allen screws holding the tank, use the longer part of the allen wrench and attach the a needle nose to the wrench. If you remove the tank enough like I do, you slowly or quickly start to strip the bolts. Using the longer end with a needlenose will keep the bolts from stripping. hth's
Green/Black 01ZX6r. LP LP flushmount v's, tank guard. Removed decals, 2002 rear fairing, Pyramid hugger
96 SVT Cobra Black/Tan Vert 32V. Not stock!
93 Blue Probe GT 24V Commuter car.
