pull off the pass. seat, in the center there is a 10mm bolt, remove it and then slide the front seat holder to the right if you looking down on it, then the front seat should come off.
On my '03 636, you put the key in the left hand side of the bike (clutch) side and turn it to get the tail piece or rear seat which ever is on to come off. There is a 10mm bolt behind the driver's seat in the opening under the rear seat that holds the lever closed to hold the driver's seat on. Take out the bolt and swing the lever to the side and the seat should lift right off.
