1 - 10 of 10 Posts
I CANNOT for the life of me get the rear axle nut loose. It is on there GOOD. any suggestions. I have some new Sportec M-1's waiting and now i'm stuck!! Yes i did take the cotter pin out. (First question of the first 2 fellas I asked);)
You really need something bigger than the wrench in the tool kit. Get an 18" breaker bar and it will come right off there. Option two is to get a piece of pipe to act as a cheater on the stock wrench.
I had to do this with the included wrench.
Basically I had to have one person hold the bike steady while I stood on the wrench and bounced [all 210lbs of me]. Once it broke loose it came off easy.
DT
hahah
i also had to bounce on the wrench with all my wieght...I'm 210 lbs as well...
seems like it was on much tighter then the required 96 ft/lbs needed...I think it's 96....
rightey tightee leftee louseee .jk. spray it wd-40 and then try it
i used a hammer the first time to loosen it.
Discussion Starter #9
thanks for the replies. I tried the bouncing on the included wrench idea..to no avail. only 185 lbs though. I used a largedcrescent wrench as well. Guess I'll try the breaker bar or pipe ideas next....good to know others had probs too.
The longer the cheater bar, the more torque you'll have. I use an old shitty torque wrench to loosen tight bolts, and if that doesn't work, I'll use a hammer on it. Maybe you should put the bike in the back of the truck and drive it to a mechanic. Use an impact wrench on that mutha.
1 - 10 of 10 Posts
