My bike has been doing the same thing that mreyna75's bike was doing http://www.KawiForums.com/forum/topic.asp?TOPIC_ID=51205. It would act like it was out of gas even though I knew it wasn't and run real sluggish, even in first gear. So I changed the spark plugs. Still will not respond. I have searched this sight for other threads that are possibly related, but nothing. Any advice will be greatly appreciated.
Discussion Starter #2
Ok so I rode it around some more, and every time it starts to bog down I open the choke and it picks back up, still with hesitation but better than before.
If you've recently riden or had the bike out in the rai, drain the tank, drain the carbs, and add fresh gas.
Otherwise, it sounds like it a fuel pump could also be the culpret.
Also check the fuel filter, that would be an easy inexpensive fix, not to mention good maintanence habit
Discussion Starter #7
Fuel filter was changed same time as spark plugs. I figure I migght as well give my bike a tune up while I am at it. Thanks guys
