Originally posted by gnance
Thanx man. I just ordered the KAW 11. Anyway looks like a easy install once I have that. Where did you mount the alarm and the perimetor sensor? And where did you run the antenna, does it have good range?
Thanks again
Ok. I took a bunch of pics I will try to describe them the best I can as for I couldn't get them to edit so I could point stuff out in them. So here goes:
Here is an overhead view of everything installed.
Here is the black wire with the inline fuse mounted to the positive terminal.
This is the main module located right behind the battery. You can also see it good in the overhead picture.
Here is the ignition kill/anti hijack module, raised out of position so you can see it.
And here it is in position. Right in front of the 3 gray connectors.
Lastly here is the perimeter sensor and antenna.
I personaly stick the antenna up through the hole in the underside of the driver seat.
Here is the paging remote.
And here are some more pics of the completed installation:
The farthest I've found the range to be for arming and disarming is about 100-200 feet. I haven't found out the range of the page yet thought.
