i was told that my Fuel Injector was undone so i need to take off the rider seat, but cant figure out how. i found this through search, but i dont think it pertains to my bike.?. 05zx6r i have 2 hex bolts in the front, but they hold the rear seat removal lever, and i wouldnt want to take them off to find out that i just made things worse.
i know, i know,, new here full of questions. but gotta start somewhere.
Remove rear seat (by opening the trunk with the key)
-at the front of the trunk, you'll see a 10mm hex bolt holding down a black clamp, that clamp holds the riders seat in place.
-remove that bolt, lift the clamp off, and then remove the seat.
Battery is right there.
-remove the 2 bolts that go into the gas tank, as they hold another clamp that holds the battery down.
-remove wires from battery and lift out
:D
there are two black plastic pieces right and left directly under the rider's seat. remove that first. then you will see a bolt directly under seat. remove that and seat comes right out.
ahhh yes,, thats what i thought, but all ive read is remove the rear seat and then it pops out. must be pre 05 zx6r's.
thank you much.
