1 - 2 of 2 Posts
Seems to be a common problem on Ninjas. Generally most people will say use the clutch between 1st and 2nd because the difference in the gearing is greatest between these two gears.
Also, be more positive with your shift.
If you do a search around you will find plenty of info on this topic :)
Red 2002 ZX-6R 636
It's not the speed that kills, it's the sudden stop...
[?]Hey you guys I have just a brand new 02 and I already have 1500 mile son it. I have a question I'm hoping somebody can help me with. When ever I punch it in first then shift into second it either grinds or falls into neutral. When ever I ride normally its fine. But when I am doing over 20mph in first it will grind into second. Is this normal or am I just not shifting fast enough?
1 - 2 of 2 Posts
